Hello,
i’m plannig to build my second computer for racing game.( forza horizon 3 or forza series or..)
I have 3 monitors ( 3 dell u2417 will be nvidia surround , resoulution will be 5760 x 1080) with i5-4670 and 16g ram.  Only one thing i’m in trouble is a selecting graphic card for good price and good performance.
There are 4 options for me but i can’t find best answer for my system.
1060 6g
1070
1070 ti
1080  - worried bottleneck
It’d be great if you give me help for selecting graphic card!
https://linustechtips.com/topic/902598-for-triple-monitors/
Get the best that you can afford. That said, a GTX 1080 would be most ideal. Don't worry about a bottleneck. At 5760x1080, most newer games will be GPU bound.
Gaming Rig
CPU: Intel i7-6850k @ 4.2GHz
GPU: 2x FE GTX 1080Ti
Memory: 16GB PNY Anarchy DDR4 3200MHz
Motherboard: ASRock X99 Extreme 4
Encoding Rig
CPU: Ryzen 7 1700 @ 3.7GHz
GPU: GTX 1050
Memory: 8GB Curcial Ballistix DDR4 2133MHz
Motherboard: Gigabyte AB350M-DS3H
https://linustechtips.com/topic/902598-for-triple-monitors/#findComment-11106694
If you really want to go Balls to the Walls, I recommend getting a Vive instead of 3 monitors. I had the pleasure to try both (with the best hardware availabe, it was a showcase) and the difference is unimmaginable. 3 monitors in surround is fine, but they almost cost as much as a VR headset, so you might as well upgrade.
https://linustechtips.com/topic/902598-for-triple-monitors/#findComment-11107484
1080 would be decent. But as it’s the best in your budget then it’s the only choice. The only thing I hate about is the connections as my monitors only have dvi.
https://linustechtips.com/topic/902598-for-triple-monitors/#findComment-11107610
