Maybe try clearing the CMOS (shortening the corresponding pins on your mobo with e.g. a screwdriver (their location should be in the manual)
    Quote=Reply      Feel free to tag me or sth if you have questions about Liquid Metal :) ROCKETS ARE LIFE        My current build:
CPU: I7 6700k@4.7Ghz 1.31sth V; Liquid Metal (Thermal Grizzly Conductonaut) | Cooler: Corsair H100iv2 | GPU: HIS R9 390 | Motherboard: Asus Z170-A | RAM: 16GB 2133Mhz HyperX FuryX | Storage: 1x 250GB Samsung 960 Evo 1x random 4TB 7200RPM HDD | Case: Lian Li Alpha  550W | PSU: Corsair RM650i | Misc.: 6x Lian Li 120mm Bora RGB Fans
My Build Log:
https://linustechtips.com/topic/902418-pc-wont-post/#findComment-11104707
2. try taking all of the ram out and booting just with one single stick at a time
3. maybe reseat the CPU
Do you hear any beep signals? @Scitesh
My Build Log:
https://linustechtips.com/topic/902418-pc-wont-post/#findComment-11104708
If that doesn't work try replugging the mobo and cpu power cables.
Also try jumpstarting it with the mobo pins and not the powerbutton
My Build Log:
https://linustechtips.com/topic/902418-pc-wont-post/#findComment-11104711
