A way to fix stereo
Sir Launcelot
I purchased an earphone, Alcatroz alpha mg-300.
then i use it casually, watch vids and gaming, it is pretty decent. However while playing league of legends, I noticed that the left and right stereo are not on their correct position. I checked the box, the reciept, then return it to the shop, but they say it is not covered by warranty (I know this is a factory defect but they say it is not). So now, I am looking for a way to swap the left and right stereo. I am not an electronic professional so I don't consider soldering the wires. Is there a software that could fix the problem?
wait what, is this the real price for it - less than $10!
http://leapfroglobal.com/alcatroz/alpha-mg-300a.html
anyway, a quick Googling around and someone seems to have had a similar issue on another tech site before, see if this works for you.
https://www.techpowerup.com/forums/threads/handy-software-for-reverse-stereo-in-windows.226167/
My Gaming PC: 27833
already tried it, it did no work. further digging, i found that there are also users with asus motherboard that says the said solution did not also work.
and yes, i'm on tight budget when i build my pc so, it cost around $8. and i get what i paid for. should have get a4tech's $4 headphones if i know that these problems are common in the brand
Two options:
1. Don't buy the cheapest piece of shit headset.
2. Get a 3.5mm male to phono female, and a phono male to 3.5mm female. Plug together backwards, simple way to reverse left and right.
haha lol, I have been in the pro audio installer business for 10 years and never thought of a solution like this but heck yes, that should definitely work!
My Gaming PC: 27833
unfamiliar to these cable, but i will try this once i found those. gotta check some shops. online shops suck in this country i live
one like this: male 3.5mm to female RCA's
and
one like this: male RCA's to female 3.5mm
Plug the RCA ends together but backwards (right into left & left into right). you then have a 3.5mm Left/Right swap cable.
