I recently ran into a problem with my display output, I have a GTX 1050 in the PCIe 1 slot and it used to work fine until yesterday, it suddenly decided to not display anything, I tried resetting my bios and nothing, now my display is off of the motherboard HDMI port , can anyone please tell me what the problem might be and how to fix it ?? PLEASE!! THANK YOU !!!
https://linustechtips.com/topic/902028-initial-display-output-not-working/
If the display output on the motherboard is not working either, it is probably nothing to do with your graphics card. I would firstly try resetting the CMOS, by removing the battery or using the jumper indicated in your motherboards manual. Let me know how it goes.
Nope, there's display on the motherboard VGA output, none in the graphics card, I even selected primary display output at PCIe 1
