I've come here to petition the liquid masters for help. I just set up my new case yesterday and moved over all my gear. What can I do besides hard tubing (going to do that later down the road) to make the loop a bit nicer looking? I was thinking a few 90 degree angle fittings .
Also, I have some quick disconnects but not sure where to hide them for a drain. Any ideas?
Intel i7 6700k|Asus Maximus VIII Hero|Asus Strix 1080|Gskill DDR4 3200|950 Pro M.2|Corsair RM750|Corsair OBSIDIAN 500D|Corsair K65\G65|SteelSeries Arctis 5|Asus PB277Q|PG279Q
https://linustechtips.com/topic/900601-aesthetic-loop-help/
if you had left more slack in the tubes you could have given them more direction and nicer curves but that's about it.
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/900601-aesthetic-loop-help/#findComment-11086850
Angled fittings can help clean up and make some of those runs more direct. I personally for soft tubing I always give an arc between two sections of fittings for aesthetics.
For the drain you can always add a QDC betweent he GPU and res or a T fitting and valve.
https://linustechtips.com/topic/900601-aesthetic-loop-help/#findComment-11087042
Thank you. I like the arc too but angle fittings mainly for the radiator down to the res.
34 minutes ago, aries757 said:
maybe some custom cover for that squarish thingy (not good with water cooling)
Thats just the flow gauge. Its actually not in the direct airflow of the radiator.
https://linustechtips.com/topic/900601-aesthetic-loop-help/#findComment-11087090
Here's some examples of what I tend to do, I try to prevent straight tubing runs wherever possible and always introduce curves or arc. For the flow gauge you could mount that along the edge of the rad.
https://linustechtips.com/topic/900601-aesthetic-loop-help/#findComment-11087153
