Hey,
I have an MSI 960 2gb and I am trying to overclock it.. I have run valley benchmark and it says my over clocking stats but RivaTuner only says what i can guess is the turbo clock. I have also tried in games, and it appears my overclock is successful but RivaTuner stats are wrong it displays 60C 1534mhz 35% load.any suggestions appreciated :)
https://linustechtips.com/topic/899949-overclock-issues/
With Afterburner installed and running?
Desktop benching:
https://linustechtips.com/topic/899949-overclock-issues/#findComment-11080765
Was it valley and heaven that don't display the real OC numbers in mhz/ghz in the top corner? Like they will display a couple hundred more then they are actually at?
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/899949-overclock-issues/#findComment-11081278
