Computer does not recognize GTX 770
Go to solution Solved by frontliner,
Have you updated your motherboard bios? I know of two people who needed to update their bios to be able to see the GTX770.
I just got my EVGA SC GTX 770 in the mail today. However, after plugging it in to my motherboard and turning on my computer I realized that it is not being recognized. I then tried uninstalling all of my previous drivers for my MSI GTX 670 using Driver Fusion but this did not help. When I go into my BIOS it doesn't even see that something is plugged into that slot on the motherboard. However the fans are spinning. When I plug the cord for my monitor into the GPU nothing shows up. The only way I can get a signal is by plugging it into my motherboard's DVI port. I then tried disabling the IGPU in the BIOS but this didn't help. Is the card faulty?? I'm really hoping it's not since it is replacing my 670 while that is being RMA'd. Is there anything I forgot or can try to get it working? Thanks for your help.
https://linustechtips.com/topic/89948-computer-does-not-recognize-gtx-770/
Did you hear a click when you plugged it into the motherboard?
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
DOA most likely. Even though the fans are spinning it's just power through the PCB, I'd say its dead. Sorry man
PC Specs:
New Compact Build
CPU: i7 8700k (Delidded)  |  GPU: EVGA GTX 1070Ti ACX 3.0 Black  |  Motherboard: ASRock Fatal1ty Z370 Gaming  |  Case: EVGA Hadron Air
RAM: Corsair Vengeance LPX 16GB DDR4 3000MHz  |  SSD: Samsung 860 EVO 1TB  |  Monitor: ASUS PB287Q
     OS: Windows 10  |  Keyboard: Corsair Strafe RGB  |  Mouse: Logitech G502 Proteus  |  Headphones: Steelseries Arctis 5
Surface Book 2 15"
CPU: i7 8650U  |  GPU: GTX 1060M  |  RAM: 16GB DDR3
Yea I made sure it was in my motherboard all the way. Man that's a shame. I was really hoping to play some battlefield since I just picked it up. Guess I'm going to have to study for my exams tomorrow instead.. What percentages of GPU's end up being DOA?
I can't seem to find a BIOS update online. I tried using the internet flash method in the BIOS but it can't connect to my internet for some reason. This is the download page for my motherboard: http://www.asrock.com/mb/Intel/Z77%20Extreme6/?cat=Download&os=Win764
Is one of those the one I'm looking for?
