I was told by a friend if I overclock my hard drive it would increase the effective speed of the CPU because it could find the files in the hard drive and not in ram so my question is the following statement:
What is the effective speed of the CPU?
Would the increase affect all 8 cores and all 16 sub cores?
CPU:AMD Rysen 7 1700x (3.4 GHz)
Hard drive:Western Digital Blue 1TB 7200 RPM 64MB Cache 3.5" Internal Hard Drive (wanting to
increase to 8850 RPM)
Thanks
https://linustechtips.com/topic/898794-advice-with-ssds/
don't listen to your friend anymore, he has absolutely no idea what he's talking about. a cpu overclock increases the clock speeds of your cpu to improve performance.
https://linustechtips.com/topic/898794-advice-with-ssds/#findComment-11069042
This is the first time ive heard of this one, I would definitely not recommend trying to increase the RPM of your hard drive.
Im not even going to go into any reasons why this would be a bad idea. But i agree with herman, dont listen to your friend anymore.
https://linustechtips.com/topic/898794-advice-with-ssds/#findComment-11069046
You can't even speed your hard drive's motor up like that. That's just stupid.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/898794-advice-with-ssds/#findComment-11069053
1.) There is no way to speed up the motor on your hard drive without some kind of warranty voiding modification.
2.) Even if sped up, DRAM memory access is orders of magnitude faster than an HDD.  I have never heard of a case where accessing data off an HDD can in any way be faster than memory.
https://linustechtips.com/topic/898794-advice-with-ssds/#findComment-11069076
