Need help for an upgrade
Go to solution Solved by factorialandha,
If you dont want the latest and greatest and just want something equal to or better than your current card, you could look at at the GTX 1060 , you can probably get one of those in that budget.
The GPU market is a little out of wack now though, so unless you NEED more vram, you might want to wait until it settles down.
