I’m using EVGA Precision to overclock my 1050ti and I seem to have hit the limit with a 150Mhz offset. Base clock when under load is 1810 I get 1987-2000 depending on temps is this my max overclock I can’t seem to get anything stable, but this is my first time overclocking so idk.
https://linustechtips.com/topic/898286-overclock-advice/
Add more voltage for more stability.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/898286-overclock-advice/#findComment-11063857
Then you should decrease the voltage a bit and monitor your temps. What's your max temp
https://linustechtips.com/topic/898286-overclock-advice/#findComment-11063879
Decrease voltage slowly and run valley and look for artifacts and once you get to the lowest voltage you can, overclock more slowly and watch for artifacts.  What exactly do you mean "i can't get anything stable".
https://linustechtips.com/topic/898286-overclock-advice/#findComment-11063930
Does the 1050ti use a 6pin connector?
Desktop benching:
https://linustechtips.com/topic/898286-overclock-advice/#findComment-11063992
I can’t get the overclock to hold under load it will crash
https://linustechtips.com/topic/898286-overclock-advice/#findComment-11064256
16 minutes ago, Ajcolby said:
Yes mine does, I have the strix oc edition
Have you maxed out the power limit? 2GHz is already a good result. If it crashes then you need to back off a bit.
Also you can OC the memory.
Desktop benching:
https://linustechtips.com/topic/898286-overclock-advice/#findComment-11064323
I have the power slider at 130% I can go up to 157 but it doesn’t seem to make a difference.
Okay i I haven’t tried that yet, does it work the same as the gpu clock?
https://linustechtips.com/topic/898286-overclock-advice/#findComment-11064399
4
Yes, but you do that to the VRAM and cant control the voltage.
Desktop benching:
https://linustechtips.com/topic/898286-overclock-advice/#findComment-11064444
