okay now i know im supposed to mention my pc parts but i built it about 2 years ago now and i cant remember. i have an amd cpu and a 500w power supply, recently my pc has been freezing up and i have to press the power button or the reset button to be able to use it again, ive tried wiping my hardrive but each time i try it stops at about 30% and does nothing, any help?
https://linustechtips.com/topic/898178-pc-freeze-crash-problem/
Plan A: try reformating your HDD by accessing safe mode in your Bios. Plan B: Buy yourself an SSD or a new HDD ( I recommend going with an SSD) https://www.bhphotovideo.com/c/product/1264782-REG/sandisk_sdssda_240g_g26_240gb_plus_sata_iii.html?ap=y&c3api=1876%2C{creative}%2C{keyword}&gclid=EAIaIQobChMIl7fors-y2QIVyrrACh2hnQiiEAQYBCABEgKWbvD_BwE
https://linustechtips.com/topic/898178-pc-freeze-crash-problem/#findComment-11062702
Best i can tell you now to change thermal paste and if that doesent help maybe try to change cpu cooler.
I know that you said that you dont know which parts you have but try remember or find out which cpu you have.
P.S. you can dowbload something like Speccy to see all you components and monitor their temperature
https://linustechtips.com/topic/898178-pc-freeze-crash-problem/#findComment-11062883
4 minutes ago, stinkyfungi said:
stock cooler and havent changed anything since i built it 2 years ago, i have cleaned the dust out regularly tho
Changing thermal paste is an option aswell, but I dont think its a solution. I think you should download aida64 and stress test cpu, cache, fpu and memory and see how high temps go, if they go to 90+ degrees almost instantly there is your problem found. Since you dont have done any oc or touched anything, your mobo is applying more voltage than needed to cpu, causing more heat
https://linustechtips.com/topic/898178-pc-freeze-crash-problem/#findComment-11062886
In my case thermal paste was solution. My cpu was running on same temperature when idle and two of my cores where on 100 degrees when playing games(like gtaV). But eventually I was forced to change my cooler.
https://linustechtips.com/topic/898178-pc-freeze-crash-problem/#findComment-11062904
Yeah I can really be a problem if not changed in 2 years
https://linustechtips.com/topic/898178-pc-freeze-crash-problem/#findComment-11062915
how long should i run the stress test?
https://linustechtips.com/topic/898178-pc-freeze-crash-problem/#findComment-11062994
Well he did say "if you see temps going high emmedietly" so... but if yoi dont see it going up then let it run for 5 min. Iam not expert at stress test tho, but i have seen plenty of people doing it for that period of time
https://linustechtips.com/topic/898178-pc-freeze-crash-problem/#findComment-11063055
15 hours ago, stinkyfungi said:
ok, done the stress test and aida says my cpu temp at idle was at 32 and max was 78, BIOS said it was at 75 earlier at idle, idk i did turn off the heating in m house and open a window but it shouldnt make that much of a difference surely
Whell it surely shouldnt make such a big diffrence but if it helps...
Are your temps now back to normal?
https://linustechtips.com/topic/898178-pc-freeze-crash-problem/#findComment-11065048
