Help on my build
Go to solution Solved by LienusLateTips,
6 minutes ago, hohoho said:
I was actually pretty satatisfied with the Air 240.
Do you have a recommensation for an mATX/ mITX AM4 motherboard?
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (€178.76 @ Amazon Deutschland)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  (€75.57 @ Mindfactory)
Memory: Patriot - Viper Elite 8GB (2 x 4GB) DDR4-2666 Memory  (€94.46 @ Alza)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  (€75.90 @ Caseking)
Video Card: Zotac - GeForce GTX 1050 Ti 4GB Mini Video Card  (€186.23 @ Mindfactory)
Case: Corsair - Air 240 MicroATX Mid Tower Case  (€89.90 @ Caseking)
Power Supply: Corsair - Vengeance 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  (€62.84 @ Amazon Deutschland)
Total: €763.66
Generated by PCPartPicker 2018-02-18 20:14 CET+0100
Pro4 is pretty ok I guess
Hello,
I'm currently putting together a list for parts for my new system.
Just a few key details:
Usage: light to medium gaming, light photo/ video editing, rendering, videoplayback etc.
Screen: not sure on it, probably 4k but gaming would be in 1080p
I've put together a list, but I still have lots of questions to be answered:
- i5 8400, i3 8350k, r5 1600 (which is the best fitting for my ideas?)
- Gigabyte/ Asus GTX 1050ti (pretty set on the type)
- 8/16 GB of DDR4 RAM 2133/2400 (anything to pay attention to?)
- ASRock Z370M Pro4/ Gigabyte Z370 D3H (both mATX, can you recommend a low priced mITX one?)
Samsung 850 EVO 250GB interne SSD & Seagate BarraCuda Computer 1TB HDD (pretty set, too)
- Cooler Master MasterLiquid ML120L (or is the Stock one sufficient?)
- be quiet! Pure Power 10 400W (or should it be modular for this case?)
- Corsair Air 240
Thank you very much for your help!
https://linustechtips.com/topic/897851-help-on-my-build/
Location? Budget?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059002
ryzen loves higher clocked RAM. Get that if you're going ryzen.
id recommend r5 1600/whatever the zen+ equivalent is.
Stock one should be sufficient.
1080p at 4k is quite shit. I have a 4k monitor. It looks reasonable after a lot of AA but I'd rather just run it at 4k lowest than 1080p high.
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059006
okay, thank you!
for which reasons do you recommend the r5 1600?
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059023
3 minutes ago, hohoho said:
okay, thank you!
Longvevity of the socket. AM4 is supported by AMD until at least 2020.
Pick one: better performance now at the exchange of not being able to upgrade later in the future
slightly worse performance now at the exchange of being able to slot in the BEST AM4 CPU in 2/3 years time.
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059039
The 1600 isn't actually worse at games with a 1050 Ti anyway so yeah, I'm behind this choice.
OP should try to get 16GB RAM but with the prices right now, 8 is fine. 8 today cost the same as 16 would have a year ago.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059044
I know
its slightly behind the 8700k though in IPC, by like 2/3%.
Technically slower. Also the 8700k can clock higher than the 1600 with overclock.
Doesn't really matter though in FPS, or system responsiveness, or CPU demanding tasks that isn't cinebench.
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059047
Oh, I didn't realise the thing with the GPU.
I heard of the RAM prices shooting up, but that much really astonishes me...
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059054
Any recommendations on the MB then?
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059062
Just now, hohoho said:
Oh, I didn't realise the thing wothe the GPU.
Here's a list that I'd give you if you bought right now.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (€179.00 @ Caseking)
CPU Cooler: ARCTIC - Freezer 33 eSports ONE (Black/White) CPU Cooler
Motherboard: Gigabyte - GA-AB350-Gaming ATX AM4 Motherboard  (€79.92 @ Mindfactory)
Case: Cougar - MX330 ATX Mid Tower Case  (€42.90 @ Caseking)
Power Supply: be quiet! - Pure Power 10 350W 80+ Bronze Certified ATX Power Supply  (€46.59 @ Mindfactory)
Total: €705.00
Generated by PCPartPicker 2018-02-18 20:01 CET+0100
The Crucial MX500 SSD is the same performance as the 850 EVO. http://www.tomshardware.com/reviews/crucial-mx500-ssd-review-nand,5390-2.html
Computer Specs:
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059068
Total: €705.00
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059081
Oh, cool you can keep the Air 240.
Grab the 1050 ti you want but don't pay more than 200euro for it.
Do this then -
Total: €747.65
Generated by PCPartPicker 2018-02-18 20:10 CET+0100
The motherboard isn't great for overclocking's sake, but we're also on the stock cooler so the best we'll do here is 3.8-3.9GHz. Aim for that if you OC.
Computer Specs:
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059097
3 minutes ago, Energycore said:
Pure Power 10 units lower than 400W are on a old Bronze group regulated platform.
CPU Cooler: ARCTIC - Freezer 33 eSports ONE (Black/White) CPU Cooler  (€30.38 @ Amazon Deutschland)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  (€85.99 @ Amazon Deutschland)
Case: SHARKOON - TG5 ATX Mid Tower Case  (€69.90 @ Amazon Deutschland)
Total: €784.46
Generated by PCPartPicker 2018-02-18 20:12 CET+0100
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059104
Total: €763.66
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059108
Do this then -
Total: €747.65
Okay, I wasn't planning to do any Overclocking for the start, but I might do it a little into using it.
And thank you soooo much for helping me! I really didn't expect it to be to quick... thanks
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059118
Oh good catch thanks.
Though on a 300W PSU i don't think I'm worried about crossloading this unit.
Computer Specs:
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059120
Total: €763.66
And thank YOU too!
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059122
Grab this PSU if you want something higher quality https://de.pcpartpicker.com/product/fyhj4D/corsair-vengeance-400w-80-bronze-certified-atx-power-supply-cp-9020106-de
Computer Specs:
https://linustechtips.com/topic/897851-help-on-my-build/#findComment-11059125
