Navida Control Panel
Go to solution Solved by DumbTrollface,
Just now, Brett_Bst said:
yes seems like it
I'd still do a clean install but for the time being just put a shortcut on your desktop
So after updating gpu drivers and getting drivers from navida site which has the gamer experience thing(I don't like or use) the control panel is now missing when I right click the desktop ?
Windows 10 - 7700k- asus 1070
I7 7700K @5.0ghz, Asus Z270-P, Corsair H115i, hyperX 16gb, Asus duel 1070, Nzxt H440
https://uk.pcpartpicker.com/list/ZTsYD8
https://linustechtips.com/topic/897650-navida-control-panel/
well just fixed it, for some reason on install it wasn't added to the startup folder so was not running on boot up, I just copied the folder to startup and it now runs :D thanks for the help
https://linustechtips.com/topic/897650-navida-control-panel/#findComment-11057021
Nice to hear.
Just make sure to mark this as answered
https://linustechtips.com/topic/897650-navida-control-panel/#findComment-11057026
I didn't actually mean to mark my post as the answer. You fixed it yourself. But thanks anyways xD
https://linustechtips.com/topic/897650-navida-control-panel/#findComment-11057071
