Hey all! Cooldablord123 here and I was just wondering if you could help me build a new rig. Not wanting anything for mining however a rig that can handle small editing workloads (mostly for college however again, SMALL) and also gaming of high settings on games like GTA V, CoD, Fortnite BR, PUBG, Fallout 4 and other Triple A titles. The budget would need to set in around $1000 USD not including keyboards, mice headphones etc because they are part of a different budget.
Thanks everyone!
https://linustechtips.com/topic/896949-pc-build-help/
building a multi purpose itx with current gpu prices with a 1000 total budget might be difficult, which are the parts/components that you already have that might help you leverage your budget? do you need to edit as part of the assignments? I mean, it's a totally different situation to be a able to deliver 444 HD or 4K prores color corrected videos than to just be able to edit a presentation for a class thats going to be viewed at web res on a H264 container format. If you provide us more details we might be able to help you build your epic rig :)
NeXTcube 12400 Z690M ITX 64GB SN770 6600XT Sugo16 12.5
NeXTserver 9400 H310N ITX 32GB SN350 5500XT Fara R1 12.5
NeXTstation 9900K Z390 ITX 32GB SN750 6800XT Enthoo 12.5
https://linustechtips.com/topic/896949-pc-build-help/#findComment-11050293
Hey mate, I'm currently on a different link because I have accidentally posted this thread twice and I will be removing this thread soon.
 That is the link to it and I am currently using the build provided, join that thread and leave some advice on the build there. Thanks mate.
https://linustechtips.com/topic/896949-pc-build-help/#findComment-11050311
