taskbar freezing, explorer not working, how?
Go to solution Solved by Sukka38,
3 hours ago, ElSeniorTaco said:
get into safe mode with networking
make sure you are connected to the internet
( if you use ethernet it will be connected and you can proceed.
if you use wifi, by default your not going to be connected, you need to click the network icon in the bottom right corner and chose your wifi and click connect)
get this tool
http://www.majorgeeks.com/mg/getmirror/tweaking_com_windows_repair_portable,1.html
run the Repair_windows.exe inside of the zip folder you get
Accept the Eula
a few tabs will be at the top, one says Repair - Main click on it
in the menu below the tabs is a button now that says "open repairs", click it
a new menu will open up
by default all repairs are selected
click Start Repairs in the bottom right corner
leave it running, it can take anywhere from 20 minutes to 4 hours
once its done it will ask you to reboot
reboot and see if it is all fixed.
Bro thanks for all your support, i freaking appreciate it so much, but I have found it.
I reinstalled windows, and one by one installed my programms and found out that Duet display was causing this.
still thank you bro!!!
So recently my pc has been very slow and my taskbar was not working (windows key, time, notifications, etc) but the apps which were open were functioning in the task bar.
So I tried to search for a solution and tried some of them, but non worked. Then I decided to have a clean install of windows. After the install everything was working but 2 hours later the taskbar was freezing again and not funtioning. And from today when I log in to my pc my screen is first black with only my cursor, after 1 min I see my desktop and everything works fine except for my taskbar.
Do you guys know any solution? Or is it perhaps time to change my hdd for a ssd or my GPU?
Akkus Kursat
https://linustechtips.com/topic/896383-taskbar-freezing-explorer-not-working-how/
press control alt delete
end task on explorer
hit file -> run on the task manger
type in explorer         or     explorer.exe
see if it starts working.
Afterwards I would run SFC /scannow
and then dism if there are no serious issues / un-repairable files
hopefully that will fix the issue without you having to dig to deep
Still not working bro :(
I noticed that when I restart explorer that my screen goes black because of that and after 1 min or so I have my desktop.
Akkus Kursat
if its windows 10
hold the windows key and tap X, hopefully a window will pop up, on there is an option to open command prompt as administrator.
Use that to run SFC /scannow
Other wise you might need to boot into safe mode to do it.
On 2/16/2018 at 3:03 AM, ElSeniorTaco said:
if its windows 10
Did that aswell, no errors found ):
Akkus Kursat
On 2/16/2018 at 3:22 AM, Sack said:
Well, I recently updated to the latest windows 10 version and had loads of problem and games lagged in menus, had to roll back to earlier version and delay updates, good job Microsoft.
Microsoft killin’ it
Akkus Kursat
On 2/15/2018 at 4:40 AM, vaiwalker said:
tried a clean boot?
run the Data Lifeguard Diagnostic for Windows by WD to check the HDD health.
I can not log in after a clean boot ?, it freezes when in try to enter my password. So freaking crazy. And the WD software turned out clean.
Akkus Kursat
if its windows 10
tried a clean boot?
I booted into safe mode and then the taskbar started to work. How can I find the culprit or any other suggestions?
Akkus Kursat
get this tool
Accept the Eula
get this tool
Accept the Eula
Akkus Kursat
