Steelseries Siberia 840 - USB Hub?
Simons
Hello folks, so I am currently trying to get some better cable management for my Siberia 840 base, I have tried setting it up with a powered USB hub, and I were able to get power through to the Base, however I am unable to get the audio through the USB Hub, do you guys have suggestions ?
CPU: i7 5820k @4.5Ghz | Mobo: MSI X99A SLI Plus | RAM: 16GB Crucial Ballistix DDR4 Quad Channel | GPU: GTX 970 @ 1579 Mhz | Case: Cooler Master HAF 922 | OS: Windows 10
Storage: Samsung 850 Evo 250GB | PSU: Corsair TX750 | Display: Samsung SyncMaster 2233 & SyncMaster SA350 | Cooling: Cooler Master Seidon 120M
Keyboard: Razer Lycosa | Mouse: Steelseries Kana | Sound: Steelseries Siberia V2
You should use the optical or 3.5mm input for audio, the USB audio (at least on my 800) is mono only.
  • 7 months later...
Just fixed a similar problem in my Siberia 840.
To get Stereo audio via USB, you have to set it up in the base:
Options -> Sources -> Edit -> PC -> choose "USB IN" -> "USB OUT"
(Chatmix and Livemix are disable, since they work by receiving chat via USB and game via Analog/Optical.)
