Just now, IDmann06 said:
My home build is having issues updating to the latest windows 10.
https://pcpartpicker.com/user/IDmann06/saved/XZPycf
 I have updated to the latest bios and made sure all of my drivers are up.  Any ideas would be greatly appreciated.
It will not let me back up my computer either
4 hours ago, Wouterrinos said:
Could you specify? Maybe a picture if that helps?
It will restart to update to the latest but when it gets 80% done, it will freeze I will force shut down, repeat, then it will restore the previous version of windows that I had before.  Then, windows will try to force update again repeating the same process over and over.
Is it freezing, or just taking a while?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
4 minutes ago, IDmann06 said:
freezing
I tried to let it update over night only with the same result.
Try just reinstalling Windows, or if you don't need the update, just leaving it.
SPECS:
I thought I mentioned this on this post but I forgot it.  I tried to backup my computer and I keep getting this error code saying error 0x80070021. Which states that I have to fresh install my computer, but I cant back it up due to this error...
10 hours ago, IDmann06 said:
the other thing is that I don't what the update is but Windows keeps forcing it on my computer.
Just try doing a clean install then.
SPECS:
You can always tell windows that you don't want to update. Google is you best friend if you have an issue with that.
If you have issues with making a backup you should atleast put important files on a usb before you lose alle your stuff.
Things like games can always be reinstalled obviously (maybe keep the savefiles), but maybe some pictures or invoices you want don't want to lose...
So I have never had to do a fresh install because I have never had this issue. Should I have to reformat my HD drive to work with the new install or will it still be compatible with the new install?
