  • 2 weeks later...
On 2/10/2018 at 9:13 AM, *insert_name_here* said:
My dad said he wants to try some smart home tech, and he's given me £100 to start off so he can see if it's worth it. What should i get?
It depends on what you want to do.  Do you want to control lights, sound system, or just answer questions?
https://linustechtips.com/topic/895051-cheap-smart-home-tech/#findComment-11061021
Tbh 100 Pounds is going to get you the very low end of home automation (If you plan to control more then 1 light/socket/ect)
And will be a bad experience that will prob turn him of the idea completely.
So like already stated in this thread: what do you want to automate/control?
https://linustechtips.com/topic/895051-cheap-smart-home-tech/#findComment-11064907
