A non hollow pipe of copper is a rod of copper. It would cool a CPU on its own, so the more you add to the other end of the copper to cool it the better it would cool but there are too many variables to determine weather your theory would work...that's why you should try it, document it and let us know how you got on!
Personally i think you need an awful lot of refinement from your basic concept because, in a nutshell, it sounds super crude. Consider how copper isn't enough without some kind of moving force be it air or water being forced across the copper.
i7 12700k @ 5.1GHz OC (EKWB) / Msi Edge wifi ddr4 / Asus TUF 3080ti (EKWB) / Acer XB327 270HZ, 3x LG 27GL83A-B 144hz, SONY KDL40D3000 Thermaltake P5 / 32gb Corsair Dominator Platinum 3600 / Samsung 980 pro 1tb NVMe ssd, Serbrent 1tb NVMe ssd,Samsung 850 EVO 500GB, Samsung 860 PRO SSD (raid), 2 TB Seagate HDDSeasonic TX 1000w titanium/ EK-FC1080 Ti GTX ASUS Strix RGB GPU Block, EK-Supremacy EVO, EK-CoolStream XE 360 [6x120 Thermaltake Ring fans], EK-CoolStream XE 360 slim [6x120 Thermaltake Ring fans],  EK-DDC 3.2 PWM Elite Edition, EK-RES X3 250 RGBMountain Everest custom with Sorbothane sound dampening / Razer Viper Ultimate, Logitec G502 , Logitec G Pro Wireless / Beardynamic DT1990 PRO with Litz wire full conversion to balanced, custom cable in Litz, Dakoni ear pads going through Topping E30 DAC to Singxer SA-1 amp/Sennhieser HD598, Sennhieser GSP 670, Custom Floor Standing Speakers in 5.1, Panasonic amp. Rode NT-USB on Rode boom.
https://linustechtips.com/topic/894417-bucket-cooling/#findComment-11024535
1 hour ago, manohar reddy said:
can we cool a desktop cpu by using a long copper pipe [not hollow pipe] flatten its ends and coil the middle of pipe and connect the ends to cpu using a custom cpu bracket and some thermal paste.After connecting the copper tube dipping it in a bucket of cold water.
That would work but not very effectively, the copper rod would conduct heat away but not as efficiently or quickly as something like a heat pipe. From there if you added fins to increase the surface area  and dipped it into a water bath it would work until the water bath heat up excessively.
https://linustechtips.com/topic/894417-bucket-cooling/#findComment-11024812
