So I am in love with my Xbox One X and my PC, but 1 is literally 16x bigger than the other, now for my next build, I would like to build a small form factor PC thats basically the same size of my Xbox. So my question is does anyone know a really good small form factor PC case that looks closely to an Xbox One X? Please and thank you!
https://linustechtips.com/topic/894380-project-scorpio-20/
node 202? there both a box
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/894380-project-scorpio-20/#findComment-11024042
one that resembles a Xbox i dunno, but i do know about the S4 Mini. probably the smalles case to fit a ITX board and a small GPU.
https://linustechtips.com/topic/894380-project-scorpio-20/#findComment-11024051
There's a project that just hit production that's just what you're looking for:
It's not cheap though.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/894380-project-scorpio-20/#findComment-11024086
