Hey there. I am looking to build a new pc and I am having a hard time now that I have a much larger budget. I know that sounds dumb but I have a budget of no higher than $800.00us. I would like to keep it around $700.00us so I can get a new keybored and mouse. Please help. I have seen some really nice Ryzen builds out there but I am not sure if they are right. I am just looking to game and do low demanding work (word and excel) on it. So mainly a gaming pc. Please help.
I know this is where to go for the true computer enthusiasts. :)
https://linustechtips.com/topic/894377-help-700-budget/
I would go for something like this:
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor  ($149.89 @ OutletPC)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3200 Memory  ($103.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($46.55 @ OutletPC)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card  ($364.89 @ OutletPC)
Case: Corsair - 100R ATX Mid Tower Case  ($24.99 @ Newegg)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($44.99 @ Amazon)
Total: $795.29
Generated by PCPartPicker 2018-02-08 07:46 EST-0500
Get an SSD later on if you want a faster OS.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/894377-help-700-budget/#findComment-11024062
-snip-
I'd step down to a 1050ti, just because it's a budget build and because he wants to spend $700 on the pc and $100 on peripherals.
https://linustechtips.com/topic/894377-help-700-budget/#findComment-11024119
Missed the peripherals thing.
Then go ahead with a 1050Ti.
Unraid Server
https://linustechtips.com/topic/894377-help-700-budget/#findComment-11024129
To be honest i would not mind on skimping on the peripherals if I can get a rockin rig. So I dont mind spending only $25 on a mouse and keyboard.
I do really like the idea of the R5 cpu and a 1060 gpu because I have had the gpu before and I really like it. I got it for a steal for $100 but had to sell the whole rig when money got way to tight. I had to eat. But now im good and after I just did my budget i can do $800 on the rig. Should I start a new thread with the updated budget or should I go with the build that is $795.29 that Eibe posted?
https://linustechtips.com/topic/894377-help-700-budget/#findComment-11026083
