Hey guys, I'm taking a Raspberry Pi course this semester and I'm looking for some assistance.
We are using Python and were tasked with the Fibonacci Sequence. How do I call? How do I get this to work?
Any help is appreciated.
    class Fib:
        def __init__(self, max):
            self.max = max
        def __iter__(self):
            self.a = 0
            self.b = 1
            return self
        def __next__(self):
            fib = self.a
            if fib > self.max:
                raise StopIteration
            self.a, self.b = self.b, self.a + self.b
            return fib
https://linustechtips.com/topic/893307-python-fibonacci-help/
def main():
      x = Fib(max)
      x.__iter__()
      x.__next()
This code added below the rest of it results in the following message in the shell. Nothing happens.
>>>> %Run FibLab3.py
Edit: I added print(x.__next__()) doesn't seem to print anything.
Also, I'm understanding this a lot more now. The x becomes an object of the class that comes after the dot. Thank you, you are being very helpful.
adding
https://linustechtips.com/topic/893307-python-fibonacci-help/#findComment-11011738
19 minutes ago, Sdot said:
def main():
      x = Fib(max)
      x.__iter__()
      x.__next()
>>>> %Run FibLab3.py
adding
You need to specify a number for max, like Fib(100). Then the program will stop when the Fibonacci number exceeds that value
https://linustechtips.com/topic/893307-python-fibonacci-help/#findComment-11011783
15 minutes ago, Sdot said:
Does this look correct?
for i in range(100):
      print(x.__next__())
Sorry cant format cause Im on mobile.
You wrote an iterator, so use it like this:
for i in Fib(100):
    print(i)
Desktop: Intel i9-10850K (R9 3900X died 😢 )| MSI Z490 Tomahawk | RTX 2080 (borrowed from work) - MSI GTX 1080 | 64GB 3600MHz CL16 memory | Corsair H100i (NF-F12 fans) | Samsung 970 EVO 512GB | Intel 665p 2TB | Samsung 830 256GB| 3TB HDD | Corsair 450D | Corsair RM550x | MG279Q
Laptop: Surface Pro 7 (i5, 16GB RAM, 256GB SSD)
Console: PlayStation 4 Pro
https://linustechtips.com/topic/893307-python-fibonacci-help/#findComment-11011936
