Remove the battery then plug it in and try to power it on. What happens?
Main Rig:-
Server:-
Thanks I'll try that, but I don't think it's a battery issue cuz the keyboard is actually responding to the dimming function.
19 minutes ago, Maximusfoximus said:
Sounds like a mobo issue. If all your components power on but you are not posting, something is wrong with bios. If you are still covered I would get it repaired. I have had
this issue before as well.
OK thanks, I'll contact them asap :)
Edit: typo
Edited by LekTiRegor
