Hello everyone, I have finally decided to build my own PC because I have a desire for PC gaming. I'm fairly new to this, so I may not be the most familiar with parts, but I do know how to build a PC as i have built one for a friend before.
Here are my goals:
1. Budget & Location
I have a budget of around $700-750 USD on the PC alone. The nearest micro center is a 50 minute drive away, but I may be able to go to one since I will be travelling soon.
2. Aim
My goal with this system is to be able to play games such as CS:GO at maximum settings/frame rate, while also being able to play newer games such as COD:WW2 at medium settings/60 FPS. It doesn't have to be overkill, but I would like to at least be able to handle newer games somewhat. I also plan on getting a 250 GB SSD drive for sure to go with a 1TB hard drive. I'm not sure what would be the best graphics card for my needs, since a GTX 1050 Ti might be too much.
3. Monitors
For right now I am only going to get one 1920x1080 144hz monitor, but in the distant future I might consider getting another one.
4. Peripherals
I'm probably going to end up buying a mouse and keyboard for cheap, so I'm not going to include them in the budget. I would like to have Windows 10 Home as my OS though.
5. Why are you upgrading?
I'm currently running on a Dell Inspiron, so the integrated graphics are pretty bad and I'm not able to play pretty much all the games I would like to play.
Any advice on builds/parts to consider are appreciated, Thanks a bunch!
https://linustechtips.com/topic/892330-building-first-pc/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($198.00 @ Amazon)
Motherboard: MSI - B350 TOMAHAWK ATX AM4 Motherboard  ($71.98 @ Newegg)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory  ($102.89 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($46.55 @ OutletPC)
Video Card: Zotac - GeForce GTX 1050 Ti 4GB Mini Video Card  ($187.79 @ OutletPC)
Case: Azza - SIRIUS ATX Mid Tower Case  ($24.84 @ Amazon)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($56.99 @ Amazon)
Total: $689.04
Generated by PCPartPicker 2018-02-01 19:48 EST-0500
have not put a list together it awhile dint realize GPU prices were this bad
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/892330-building-first-pc/#findComment-11001730
Hello!
Don't have the time to suggest you a build, but keep in mind that this is a bad time to build a PC, due to GPU and RAM pricings.
Also, you can have Windows 10 from Kinguin for about 25 USD. That can save you some cash.
Chasis: Lian Li O11 Dynamic Evo || PSU: Seasonic PX 650 || Mobo: MSI Z690 Pro A || CPU: Intel i5 12600K || CPU Cooler: Lian Li Galahad AIO 240 || RAM: G.Skill Ripjaws V 32GB @3200 || GPU: AORUS 4070 ti Elite || Boot Drive: Samsung 850 EVO 250GB || Secondary Drive: Crucial MX300 525GB || HDD: WD Caviar Blue 1TB || Intake Fans: 3x Lian Li UniFan SL120 || Exhaust Fans: 2x Lian Li UniFan SL120 || Mouse: Logitech G Pro Wireless || Keyboard: Das Keyboard 4Q with Cherry MX Browns || Monitor: Acer Predator IPS 165Hz GSync
https://linustechtips.com/topic/892330-building-first-pc/#findComment-11001736
Don't buy parts for a pc right now, specifically ram and graphics card(s). Theyre severely overpriced.
If you really want to get into it, maybe take a look at pre built gaming pcs
https://linustechtips.com/topic/892330-building-first-pc/#findComment-11001737
