I was trying to sort flash out on my Ubuntu based laptop, I turned away for a moment and the laptop died, completely, it won't turn on, it won't charge, it won't do shit. After opening the bottom of the laptop I found the screw that was rattling around inside, It was wedged next to the fan, and power. Could this have shorted the laptop out?
Cpu: i5-2500k @4.8Ghz, MB: Asus Maximus V Formula, CPU cooler: Be quiet! Dark rock pro 2, GPU: Evga Gtx660 FTW@1.24ghz. Ram: Corsair Vengeance 8GB 1866Mhz, PSU: Be quiet! 730w Semi modular, SSD: Corsair force 3 240Gb, HDD: WD Green 1TB, Case: Nzxt H2 with 4 Corsair SP120's, Win7
https://linustechtips.com/topic/89038-laptop-died-help/
probably
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/89038-laptop-died-help/#findComment-1205051
Possibly.
probably
Wonderful, the cunting thing lasted numerous years of abuse and now it shits on me. Ughh.
https://linustechtips.com/topic/89038-laptop-died-help/#findComment-1205078
Update: Looks like my charger took the brunt of the short out and the charger is dead, managed to ghetto charge my laptop and it booted directly into Ubuntu.
https://linustechtips.com/topic/89038-laptop-died-help/#findComment-1205151
Second upate: No idea what the hell is causing the random shut offs, it happened again when it magically worked on the normal charger.
https://linustechtips.com/topic/89038-laptop-died-help/#findComment-1205189
