Badly need help
Solved by RobertS,
Are you using a VGA cable? If yes, try swapping it out for a HDMI, DVI or DP. It could be a fault with either the port or the cable. That is the only thing i can think of
kerriya ·
Posted in Cases and Mods4 -
octester ·
Posted in Troubleshooting5 -
DavidPatrascu ·
Posted in General Discussion7 -
2
3
bill well ·
Posted in Peripherals1 -
4
2
play_circle_filled
Latest From ShortCircuit:
