Just now, Swaggin Dragon said:
Visually the same design, but with white leds. Soldering this is too much work (have already tried)
1
You have MSI's only keyboard so if you want that same yellow accent and exact same design, you're out of luck. You'd have to mod or get a different keyboard, which would mean a slightly different design.
https://linustechtips.com/topic/889971-keyboard-help/#findComment-10977545
