Hub to commander Pro
Go to solution Solved by W-L,
20 minutes ago, HappyDog_420 said:
Hey community,
So, in the commander pro demo presented by Corsair, the man says you can control the fans with the commander pro.
I have the commander pro as well as the hub that I got with my 3x HD120 RGB Fans from Corsair, but I can't figure out how to link both of them.
I'd like to control my fans' lighting with Corsair Link.
How do I proceed?
That would be correct you need to use a cable to interconnect the hub to the commander Pro, which would be included with the Commander unit.
Hey community,
How do I proceed?
RGB & Fan control ULTIMATE GUIDE !
https://linustechtips.com/topic/889598-hub-to-commander-pro/
Hey community,
How do I proceed?
https://linustechtips.com/topic/889598-hub-to-commander-pro/#findComment-10974064
Oh, so a 3pin to 3pin was included with the commander pro? All I need to do is connect the hub to the led channel then.
Thanks!
https://linustechtips.com/topic/889598-hub-to-commander-pro/#findComment-10974074
Thanks!
Yes from there you can configure your lighting channels and effects for the fans connected to the fan hub. Just remember the fans need to be populated sequentially in the hub, ie. starting with port 1, 2, 3 and so on.
https://linustechtips.com/topic/889598-hub-to-commander-pro/#findComment-10974081
Noted, thanks for the tip :)
https://linustechtips.com/topic/889598-hub-to-commander-pro/#findComment-10974085
