Hello all! I have been working and ding research, checking reviews etc. This is what I've come up with for a gaming PC that isn't too unbelievably pricey. Of course my lists non-essential hardware such as monitors. so it comes out at about $1,300. Is there anything I could get differently to save money or get more power out of it without spending more? Also is there anything missing that I should also lookout for? Any suggestions would be amazing!
Power Draw: 290W
PCPartPicker part list: https://pcpartpicker.com/list/LhGxZ8
Price breakdown by merchant: https://pcpartpicker.com/list/LhGxZ8/by_merchant/
CPU: Intel - Core i5-6600K 3.5GHz Quad-Core Processor  ($209.99 @ Amazon)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.49 @ OutletPC)
Motherboard: Asus - MAXIMUS VIII HERO ATX LGA1151 Motherboard  ($149.24 @ Newegg)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($204.99 @ Best Buy)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Amazon)
Video Card: Asus - GeForce GTX 1050 2GB DUAL Video Card  ($194.99 @ Newegg Marketplace)
Case: Corsair - SPEC-OMEGA ATX Mid Tower Case  ($99.99 @ Corsair)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($50.54 @ Amazon)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($89.89 @ OutletPC)
Software: Malwarebytes - Anti-Malware Premium (1 Year Subscription) Software  ($29.99 @ Amazon)
Sound Card: Asus - Xonar DGX 24-bit 96 KHz Sound Card  ($35.89 @ OutletPC)
Wired Network Adapter: TP-Link - TG-3468 PCI-Express x1 10/100/1000 Mbps Network Adapter  ($12.88 @ OutletPC)
Monitor: AOC - U2879VF 28.0" 3840x2160 60Hz Monitor  ($297.90 @ B&H)
Keyboard: Corsair - K65 RGB Wired Gaming Keyboard  ($79.95 @ Amazon)
Mouse: Logitech - G900 CHAOS SPECTRUM Wireless Optical Mouse  ($84.99 @ Best Buy)
Total: $1624.71
Generated by PCPartPicker 2018-01-24 18:27 EST-0500
>>>It is for gaming<<<
Edited by dwright
https://linustechtips.com/topic/889524-my-first-build/
Are you gaming on this or just general tasks?
6600 is old and out dated, swapped it out for an 8400 which will give you more cores for the same price and also perform much better.
Swapped out the board since the processor was changed
Dropped the cooler since the stock is fine for the 8400
Added an SSD for added performance from boot times, loading times, reduced latency, and overall snappiness
The motherboard comes with a sound card and has Ethernet, dropped both of those since they are not needed.
Swapped the PSU for a better and more modern PSU as well.
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($201.88 @ OutletPC)
Motherboard: ASRock - Z370M Pro4 Micro ATX LGA1151 Motherboard  ($121.98 @ Newegg)
Storage: Crucial - MX300 275GB 2.5" Solid State Drive  ($89.89 @ OutletPC)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($28.98 @ Newegg)
Total: $1550.42
Generated by PCPartPicker 2018-01-24 18:35 EST-0500
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/889524-my-first-build/#findComment-10973351
Get w10 from kinguin, you'll save like $60
Im assuming this isnt for gaming?
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/889524-my-first-build/#findComment-10973367
Yeah if you're only going to spend so little on a sound card don't bother. Ive got this mobo and supreme fx is fine. Actually a cheap sound card and supreme fx are both underwhelming. I went with using my amp instead. If you have a spare amp hook that up using an optical cable.
i7 12700k @ 5.1GHz OC (EKWB) / Msi Edge wifi ddr4 / Asus TUF 3080ti (EKWB) / Acer XB327 270HZ, 3x LG 27GL83A-B 144hz, SONY KDL40D3000 Thermaltake P5 / 32gb Corsair Dominator Platinum 3600 / Samsung 980 pro 1tb NVMe ssd, Serbrent 1tb NVMe ssd,Samsung 850 EVO 500GB, Samsung 860 PRO SSD (raid), 2 TB Seagate HDDSeasonic TX 1000w titanium/ EK-FC1080 Ti GTX ASUS Strix RGB GPU Block, EK-Supremacy EVO, EK-CoolStream XE 360 [6x120 Thermaltake Ring fans], EK-CoolStream XE 360 slim [6x120 Thermaltake Ring fans],  EK-DDC 3.2 PWM Elite Edition, EK-RES X3 250 RGBMountain Everest custom with Sorbothane sound dampening / Razer Viper Ultimate, Logitec G502 , Logitec G Pro Wireless / Beardynamic DT1990 PRO with Litz wire full conversion to balanced, custom cable in Litz, Dakoni ear pads going through Topping E30 DAC to Singxer SA-1 amp/Sennhieser HD598, Sennhieser GSP 670, Custom Floor Standing Speakers in 5.1, Panasonic amp. Rode NT-USB on Rode boom.
https://linustechtips.com/topic/889524-my-first-build/#findComment-10973369
Total: $1550.42
It's for gaming! Also do you think I'll need any case fans or should it be good the way it is?
https://linustechtips.com/topic/889524-my-first-build/#findComment-10973373
Total: $1550.42
2160p with a 2GB 1050? is this for real?
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/889524-my-first-build/#findComment-10973378
Yah, that's why I was questioning if it was for gaming or not.
Of course with GPU prices as screwed up as they are, a $200 1050 (non-Ti model) doesn't surprise me.
OP, I would highly suggest waiting for prices to come down on GPUs to get something that can drive games better and also dropping to a 1440p or 1080p monitor.
Prior Build Log/PC:
https://linustechtips.com/topic/889524-my-first-build/#findComment-10973383
Sorry I'm still new to most of this. I never purchase till I'm 100% certain though, and I never buy all at once. This will probably change a whole lot as time goes one. It'll take a year to get all the parts and I'm only buying the case right now.
https://linustechtips.com/topic/889524-my-first-build/#findComment-10973396
np, you should use a 1080p monitor with that card, also I wouldn't recommend a wireless mouse if you're going to play, it'd be more than bad to run out of batteries right in the middle of an important fight, also the input lag
https://linustechtips.com/topic/889524-my-first-build/#findComment-10973407
