i am thinking of buying parts and building a pc mostly for gaming but a bit of productivity will be done on it. The parts im thinking of getting are the GigaByte GeForce GTX 1070 G1 Gaming, Corsair Vengeance LPX 2x8gb, Samsung EVO 500gb ssd, intel core i7 7700k 4.2ghz, msi z270 sli plus, nzxt s340 elite case, 650 watt corsair power supply, and i dont know what cooler. Does this sound like a good build im new to this and want to be able to run games smoothly at high settings.
https://linustechtips.com/topic/888801-help/
It looks like a good gaming/productivity system except that the CPU is one generation old.  It's plenty capable still, but there are better options from intel and AMD for similar money.  If you have your heart set on the 7700K then go for it, but if you haven't bought yet, consider the 8600 and 8700 series from intel and the R7 ryzens from AMD.
https://linustechtips.com/topic/888801-help/#findComment-10965887
It sounds like a solid build (maybe look into Ryzen/Coffee Lake instead of i7 Kaby Lake). However, RAM and GPU prices are extremely high right now... It depends if you want to pay a much higher price than usual.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/888801-help/#findComment-10965892
I know prices are going up in places like the USA but hear in Australia 1070 is still at about $700 AUD
https://linustechtips.com/topic/888801-help/#findComment-10965896
ill have a look ill probs buy in a month or two
https://linustechtips.com/topic/888801-help/#findComment-10965901
2 minutes ago, xKijjvs said:
would a 1TB WD blue hard drive be good?
Yes.
Unraid Server
https://linustechtips.com/topic/888801-help/#findComment-10965924
is a i7 7700k quad core 4.2ghz or a i5 8600k hex core 3.6ghz better
https://linustechtips.com/topic/888801-help/#findComment-10965928
Just now, xKijjvs said:
are either of the cards way better than the other? and whats the difference between 6 core and 4 core
i think they used the same card, but that's not the point, they are not CPU intensive games that you can notice the difference. And even the card was under utilized at that resolution. That was my take from it.
It depends on what games and tasks you use you PC for.
https://linustechtips.com/topic/888801-help/#findComment-10966021
i just want tto be able to play games like ARK, Subnautica, Forza Horizon, GTA V at high settings with 60fps and maybe a couple mods on gta. Although i need to be able to light/moderate video editing.
https://linustechtips.com/topic/888801-help/#findComment-10966036
Either CPU will do those games at the FPS you are looking for.  I'd go 8600K.  Newer platform.  Cores are better than threads when you get right down to it.
Also there is an upgrade path.
7700K is the best Z170/270 has, the 8600K has upgrades on Z370.
https://linustechtips.com/topic/888801-help/#findComment-10966261
alright cool the z370 is only $10 more
https://linustechtips.com/topic/888801-help/#findComment-10966278
