there is some type of device disconnecting and reconnecting 3-8 times for about 10 minuts then just stops for a while and it repeates but i cant finde anything missing when its disconnected my headset mouse and keyboard all works fine when its disconnected same with my webcam and corsair h100i cooler and i cant figure out what the device is since its not connecting to device manager and the notification on windows 10 just says its failed to recognize any clue?
started before i reformated and its stil here after the format
EDIT: found the device but i cant finde the name but i found a location Port_#0010.Hub_#0003 no clue what that means tho
just to clearify i have tried plugging all my usbs and tried the remaining ports with my iphone just to se if they work and the phone charges in all of them
Cpu: intel i7 4790k    Motherboard: MSI GAMING 5   GPU:Nvidia GTX 980Ti   PSU: Corsair AX 760 PSU  RAM:Crucial DDR3 Ballistix Tactical 24GB RG  SSD: OZC Vertex 4 128GB  HDD: 2x1tb WD  Case: Thermaltake Level 10GT Snow edition!
https://linustechtips.com/topic/888151-1-annoying-usb-problem/
If everything works well and the notification is just annoying you, you can go to settings - devices- USB - and untick "Notify me when there's a problem connecting to a USB device"
Probably not exactly what it says but, I'm not using an English version of windows so, I tried my best to translate it. :P
Here's a picture:
Make sure to quote or tag people, so they get notified.
https://linustechtips.com/topic/888151-1-annoying-usb-problem/#findComment-10959248
1 minute ago, Cyberspirit said:
If everything works well and the notification is annoying you, you can just go to settings - devices- USB - and untick "Notify me when there's a problem connecting to a USB device"
Probably not exactly what it says but, I'm not using an English version of windows so I tried my best to translate it. :P
Here's a picture:
  Reveal hidden contents
i was like yes! thats amazing just what i wanted and the sound is stil there -.- thanks for trying tho :)
https://linustechtips.com/topic/888151-1-annoying-usb-problem/#findComment-10959253
IYou could try to reconnect (unplug and plug in) all front panel USB connections in your PC as it sounds like a hardware issue. Also, I'm not sure if you've tried this: plug in one device at a time and see if it connects without issue. If it connects fine, unplug and then connect the next device. Retry with all USB devices you have.
Intel Core i7 8700k | be quiet! Dark Rock 4 | Fatal1ty Z370 Gaming-ITX/ac | 32 GB G.Skill TridentZ | 256 GB Intel® SSD 600p Series | ZOTAC GeForce® GTX 1080 Ti Mini | Fractal Design Node 304 | Cooler Master V750 | Asus MG279Q | Asus VC279 | Logitech G710+ | Corsair M65 Pro RGB
https://linustechtips.com/topic/888151-1-annoying-usb-problem/#findComment-10959261
Then it might be something else that's having problems. Does it give any more information other than failed to recognize?
https://linustechtips.com/topic/888151-1-annoying-usb-problem/#findComment-10959265
i have tried this every usb is working fine keyboard and all other prefs are working fine i even tried charging my phone in any of the other ports thats unused works and connects just fine (phone wasnt charging when problem happend)
code 43 and 45 and location Port_#0010.Hub_#0003
https://linustechtips.com/topic/888151-1-annoying-usb-problem/#findComment-10959268
Unplug your front panel USB from your mobo to see if the issue persists. This is just an attempt to figure out which USB port is actually causing the problem.
Also, plug your mouse into every single USB port to see if it works in all ports in an effort to find the broken one (if there is one).
https://linustechtips.com/topic/888151-1-annoying-usb-problem/#findComment-10959286
According to this website, it could be your chipset drivers that are messing up. Try running this tool.
OR
Try what the OP said in the post on that forum:
Quote
I turned off the PC, UNPLUGGED the computer, waited several minutes, and now it seems the error has gone! Need to wait more to confirm if the problem will reoccure or not. so far few hours, error-free!
https://linustechtips.com/topic/888151-1-annoying-usb-problem/#findComment-10959298
i kinda did just with my iphone as it makes a sound when ever its unplugged and plugged in and its not made a sound in any of the porst even the front once i will try to disconnect the front usb io when ever i have a litle charge on my phone
OR
doing this now it just the same port and hub as mine is saying
well its still there
https://linustechtips.com/topic/888151-1-annoying-usb-problem/#findComment-10959299
Did you reinstall your Chipset drivers?
yes but now i found the problem my k95 keyboard has 2 usbs and as far as i know i needed both usbs for it to work but one of them is disconnecting all the time for some reason tried moving the usb and moving the potetial problem and the usb is still unregognized now but its not disconnecting as of this time was i about to say when it disconnected again but now i know what is making it
https://linustechtips.com/topic/888151-1-annoying-usb-problem/#findComment-10959354
