So i switched cases into the Define R6, I have two dual 45's two 90's four extenders and a drain valve. It is going to be a hardline loop. Here is what im hoping you guys can help me with, i want a simple looking run with at most 2 bends per a tube, but i do really care about looks if you need any more info just tell me. ( the fittings on the rad are in the basement for ease of draining) there is a GPU and CPU that will be cooled in the loop.
https://linustechtips.com/topic/888147-need-help-planning-a-run/
you want to use soft or hard line.
I use bitspower fittings. Soft line is easier to run do to the fact it is easier to work with and just a bit more forgiving.  Hard line is a bit more work.  I am now just getting my new system done with hard line and it takes a bit of work.  Looks great but lots of love going into it.
Bitspower makes both hard and soft compression fittings.  One thing you want to decide is what size.  1/2" 3/4" 5/8" and so on.  Then get everything to match that lines your running.  I doesn't do you justice if you have 12mm with 14mm fittings.  Water will shoot out everywhere.  With the D5 pump you have wont take long to make a mess.
Pump/Res > CPU - Two bends, go straight across then up and then directly into the CPU port
CPU > GPU - Go out from the CPU and then bend down straight into the GPU
GPU > Rad - Down a bit and then bend to the right and then bend again and use fittings to line it up with the rad ports
Rad > Pump/Res - Use one 90 degree fitting to go straight down, bend to line up with the rad port.
If you have a T-fitting then you can put that in the bottom between the Rad > Pump run and then run soft tubing for a drain line.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
Just now, Dreaper said:
Any way to make it so I don't have to do a four bends in one tube?
You can have it going straight up and one bend into the CPU, the four bend is just for bling.
1 minute ago, Dreaper said:
Ok and you think it will still look good?
thats up to you to decide.
2 minutes ago, Dreaper said:
I'm asking YOUR opinion also if I choose to do the four bends in one tube is it ok to do one bend then let it cool and then reheat for the rest?
I think it would look fine, maybe perhaps on the simple side. Its fine to let it cool and do another bend, in fact thats probably the way it should be done.
Ok I shall attempt and go from there
last thing is where should i put the extenders, dual 45's, and ballvalve or just tell me what color the stuff is
blue, dual 45
teal 90
red, t-splitter
ball valve on the t-splitter
and extenders where you find it helps (no fixed place)
cpu --> pump in
pump out --> rad
@Dreaper As another point, your fans are in exhaust configuration at the moment, If this is intentional, fine, but personally I would flip the fans,.
mmk and im a little confused on the rad part do you think you could skype or discord me whenever your free?
Won't be available for a good week or so, so unfortunately you'll have to try to figure it out.
Your front fans are backwards. Gonna be choking your system of airflow if you leave them that way.
Main System-
Case: Lian Li PC-O11 Dynamic PCMR Limited Edition
Motherboard: Asus X570 Crosshair VIII Hero WiFi
CPU: AMD Ryzen 9 3950X
GPU: Asus GeForce RTX 2080Ti Strix OC
RAM: 4x16GB (64GB) G.Skill Trident Z Neo DDR4 @ 3600MHz/C16
Storage: 1x Samsung 970 Evo 1TB NVMe M.2 SSD (OS), 4x Samsung 860 Evo 2TB SATA SSD
PSU: EVGA Supernova G3 1000
Cooling: Custom Loop, EKWB Quantum Velocity Copper/Plexi w/ D-RGB Upgrade Kit and Black Frame, EKWB Quantum Vector Strix Nickel/Acetal D-RGB w/ EKWB Strix Backplate in Black, Watercool MO-RA3 420 LT (180-200mm Fan Mount, Classic Black Grill High Version, Wall Mounting Bracket, Heatkiller Tube Mounting Bracket, PCIe Slot Terminal Adapter), Heatkiller Tube 200 w/ EKWB D5 PWM Pump, Bitspower Fittings, 6x EKWB Vardar X3M D-RGB 120mm Fans, 4x Noctua NF-A20 Chromax 200mm Fans, EKWB ZMT Tubing, EKWB HD-PETG Tubing
ITX System-
Case: NCase M1 V6.1
Motherboard: Asus X570 ROG Crosshair VIII Impact
CPU: AMD Ryzen 9 3900X
GPU: NVIDIA GeForce RTX 2080Ti Founders Edition
RAM: 2x16GB (32GB) G.Skill Trident Z Neo @ 3600MHz/C16
Storage: 1x Samsung 970 Evo Plus 500GB NVMe m.2 SSD (OS), 1x Samsung 860 Evo 2TB m.2 SSD (Storage)
PSU: EVGA Supernova 650 GM (SFX)
Cooling: Custom Loop, Watercool Heatkiller IV Pro Black Copper (AM4), Watercool Heatkiller IV RTX 2080Ti Acetal Nickel w/ Black Backplate, 2x XSPC TX240 Radiators, Iceman Cooling Ice P5 Pump/Reservoir Combo, Bitspower Fittings, EKWB ZMT Tubing
