If the GPU cooler is an open air design then it's dumping heat inside the case.
Heat rises so the CPU cooler is sucking it in.
https://linustechtips.com/topic/888125-hot/#findComment-10958964
9 minutes ago, Jack Dvorak said:
Eh...passively cooled GPU is still radiating heat into the case.
https://linustechtips.com/topic/888125-hot/#findComment-10958999
