Mini Display Port
Solved by Glenwing,
1 minute ago, AWayne said:Alright so there is basically no advantage in having a mDP over HDMI besides variety?
DP ports can connect to either DP, HDMI, or DVI displays with a simple cable, HDMI can only connect to HDMI or DVI displays. DP has more flexibility in that regard, but for connecting to a DVI or HDMI display it doesn't matter whether you do if from a DP port or an HDMI port.
