So recently my older brother has bought the same computer as me a
1080ti msi duke
Ryzen 7 1700
Msi 350 mate motherboard
The issue is he is only getting 90 fps in overwatch on high settings while i get around 200 on the exact same settings.
Both our computers only use a % of its resources for example my graphis card only hits 40% usage. My cpu hits around 15-20% while playing and ram is around 50%.
So I was wondering if there was anyway to get overwatch to use more of my computer so I could push higher fps.
He has a 144hz 1920x1080 monitor and i have a 240hz 1920x1080 monitor.
Yes we have drivers and they are all up to date
https://linustechtips.com/topic/887335-computer-help/
Compare your temps with something like HWMonitor, do either one of you have overclocks? There's a lot to compare, from your game profiles in your NVidia settings to the settings in your BIOS. Also what is your RAM speeds compared to his? For example a Ryzen CPU should run better on 3000-3200Mhz RAM than 24000Mhz RAM, although it wouldn't be nearly that big of an FPS gap.
https://linustechtips.com/topic/887335-computer-help/#findComment-10951431
Is V-snyc enabled? Also I have found that some settings will have more GPU impact then one would think (the specific ones elude me right now). Also not all components are not made equally. Just because you both have Ryzen CPUs and the same GPUs and motherboard does not mean they all will preform at X specs. I am talking about the "Silicon Lottery". Most of the time the components will preform extremely close to X specs but sometimes they will not. This is beyond your control. I would also check out Overwatch's forums to see if anyone else is having the same or similar issue.  Also make sure that the BIOS is up to date.
However these are the easiest steps you can take to narrow down the issue:
Step 1: Swap monitors. for a day or two swap monitors, and see if that makes a difference then obviously switch back..
Step 2: Swap GPUs. Just like above swap GPUs for a day or 2.
Step 3: If you have another drive kicking around (doesn't matter what type) load a FRESH load of windows 10 onto it. Install drivers from the Manufacturer's website and then install Overwatch and see if the same issue occurs.
Step 4: With Fresh load repeat steps 1-2.
I hope this helps.
Vindicator Main Rig: CPU: i7-5930K MOBO: ASRock Extreme 6 RAM: 32GB Corsair Vengeance LPX GPU: Gigabyte G1 Gaming GTX 1080 Storage: 256gb WD Black NVME (Boot), 1TB Mushkin Reactor SSD (Current Games), 4TB WD Black (Other Games), and 2TB WD Black HDD (everything else) CASE: Cooler Master CM Storm Trooper PSU: Corsair 750W Semi-modular 80+ Bronze.
Unkown Regions Home Server: CPU: AMD A10-5800K MOBO: ASRock FM2A88M Pro+. RAM: 22GB of Various DDR3. (2GB Dedicated to iGPU)  Storage: 180GB SSD (Boot and Program Storage), 10TB (3x WD Red 2TB and 1 Seagate Ironwolf 4TB ) in a Windows Storage System  CASE: Fractal Design Node 804 PSU: Cooler Master 400W White label.
Abomination (Work from Home/Tinker Machine) Station: CPU: Intel Xeon E3-1270v2 MOBO: Intel DQ77MK mATX. RAM: 4x8GB Crucial (1600) DDR3, GPU: Nvidia Quadro 600, Storage: 128GB mSATA (In a 2.5" adapter")x2 in Raid 0, and 250GB Velicoraptor, PSU:450 Bronze EVGA, Case: Re-purposed ACER VERTIRON Case
https://linustechtips.com/topic/887335-computer-help/#findComment-10951485
My temps are fine cpu is never past 50 and gpu is never past 65 i havr 3000mhz ram and my brother has 3200 mhz both of us have 16gb
https://linustechtips.com/topic/887335-computer-help/#findComment-10951542
I hope this helps.
Silicon lottery would not half your fps and i do need to check my bios thanks i will when i get home and let you guys know
https://linustechtips.com/topic/887335-computer-help/#findComment-10951546
And your brother's temps? He is the one having the problem after all.
https://linustechtips.com/topic/887335-computer-help/#findComment-10955302
