Hello,
I don't know if this is the best subforum to do it in but I thought it would fit best here.
I need led strips for my table, they will be used as background lighting.
Now thus far there is no problem but I am a bit of an idiot. What should I look out for? What is a good feature and whats garbage?
I would like them to be controlled from my phone and have more than just block colour, maybe even things like waves (like on an RGB keyboard)
Does a ready buy solution exist or would I have to make something myself?
Kind regards,
The Cliff
https://linustechtips.com/topic/886651-looking-for-led-light-strips/
2 minutes ago, TheCliff said:
Hello,
Kind regards,
The Cliff
Whats your budget? You can get like 16ft of cheap RGB light strips on Amazon for $19. However, the sky is the limit when it comes to cost.
For controlling from your phone, there are a number of bluetooth controllable strips. If you already have some type of home automation setup, you could look at the Phillips Hue options, but its like $80 for 6 feet.
80 bucks is quite alot. I thought of a maximum of 50 bucks for what are about 8 feet.
I still may look into phillips hue. Thanks for the tip
