Hey,
I am wondering exactly the same, same boat.
The thing is that unless you need it NOW you're probably better off waiting for Intel/AMD Vega combo, or even coffee lake mobile. Tho it would probably still be pascal arch from nvidia, unless again, you wait for volta mobile from nvidia (which is Q3 '18 probably).
I know, thought choice.
I personally try to hold off to buy any old tech, as I dont need it now.
https://linustechtips.com/topic/886260-e-gpus-vs-max/#findComment-10941127
