steamOS problems entering first command
Go to solution Solved by technovore,
FIXED: I made the iso using isocreator http://sourceforge.net/projects/iso-creator-cs/files/latest/download
instead of my usual IMGBURN.
it took the auto-completion and I got a few steps further
Pic says it all.
According to this guide, that's the command I have to enter: http://steamcommunity.com/groups/steamuniverse/discussions/0/648814395797000712/
Am I doing sth wrong here?
Grammar nazis are people too!
Treat your local grammar nazi nicely and he might teach you a thing or two. (Note that I'm Belgian and not a native English speaker.)
Chivalry isn't dead!
https://linustechtips.com/topic/88593-steamos-problems-entering-first-command/
I got past the install but it wouldn't boot in my VM. I also herd that only nvidia cards are supported so it might not even run in a VM at all.
It does in this video: https://www.youtube.com/watch?v=glTxRlT1RpM
ur not typing is properly its case sensitive
the second attempt u have to have FS as capatalized
dont think that will work becaus i also have the same issue and typing it capatalized didnt make a difference
If you tell a big enough lie and tell it frequently enough it will be believed.
-Adolf Hitler
 tried in all caps, didn't make a difference
t might not be FS0:\, type "map" and see if that directory exists on one of the other devices.
------------------------------------------------------I HAZ SHINY----------------------------------------------------------
I'm not a linux expert
replace FS0 with BLK0 and try
it's a numerical 0 and not an o right?
try press tab after typing
FS0:\E
what tab does is fill in the first known directory. if you do not get it to fill with
FS0:\EFI\
you can then type b and hit tab again and it should populate with BOOT.
if this does not work then you may have to check to make sure that your iso file is still mounted perhaps.
Pic says it all.
Use the quote or multiquote, for faster responses \/ \/
FS0:\E
FS0:\EFI\
there was no auto-completion in any of the above scenarios
