PC randomly shutsdown under load?
Solved by tehx,
Just now, Dacobi said:Hi
I recently build a new gaming PC that ran fine for several weeks.
But now it's started to randomly shutdown when running demanding games (like DOOM, Mass Effect, etc).
The PC is a 8700k, Gigabyte 1080ti, Asus Z370 Prime-A, Corsair Vengeance LED DDR4-3200 DC - 2x8GB
The PSU is an older CX750M
Bot CPU and GPU is watercooled.
My CPU temp maxes out at around 66C and GPU at around 60C
Anyone got any idea whats causing this???
I had the same problem turns out for my 24pin was not plugged into mobo properly. Also, check psu for dust
