I was running games on the integrated Gpu of my motherboard, but I finally got around to buying a new graphics card but after installing it the drivers wont install, it just says that the product is already installed. I even removed all Drivers and it still said that they where installed...
Also right after installing the card I tried to play some games and I got some issues with OpenGL (Don't know why)
My mother board is ASUS A55BM-E & my GPU is Radeon RX 560 strix
plz help, I am not good with PC's!
[Side note] It apears as tho my PC can't even detect it, as when I open AMD catalyst control centre I can't find anything saying that I have a GPU installed.
https://linustechtips.com/topic/885029-problem-with-my-gpu/
23 hours ago, Geodarian said:
The 560 GPU is installed into the mobo?
GPU to Monitor using HDMI?
Booting the computer results in a picture? or no?
IF you get picture its working fine.
I7-7700k@5.1ghz + 1080ti @ 2050mhz + 32gbs Ram + 2TB SSD = CSGO
i7-6700k@4.9ghz + 980ti @ 1501mhz + 16gbs Ram + 1 TB SSD = Backup
i7-3770k@4.8ghz + 680 4gb + 32gbs Ram + 500gb SSD = Retired/Office work
https://linustechtips.com/topic/885029-problem-with-my-gpu/#findComment-10933442
