Hello, I bought this chinese laptop, brand ENZ and I can not install the updated drivers from nvidia... Here is a detailed explanation of the video that I am posting on youtube about the issue.
https://youtu.be/YsX6M442ox8
In the video first you can appreciate how I try to update the drivers from geforce experience, it does not work, then i go to nvidia's website and try downloading the latest driver for my device which is a gtx 960m on windows 10 64 bit, I try to install it, it does not work, then I try to modify a file for it to recognize my graphics card, and it does recognize it and starts the installation but it fails anyway, and I tried all this in safemode too but it is not shown on the video... Then there are no updates from windows update for my card unless I uninstall them in safemode with DDU, and suddenly, the menu of nvidia, the nvidia control panel is gone, when I start a game no matter if I select use nvidia gpu on the nvidia control panel when it WAS there, you can see that it is using the integrated intel graphics, it never uses the dedicated 960m graphics, and now, the 960m display adapter option is gone after attempting to update the drivers from geforce experience or via the nvidia's website, only after a restart windows update will install very OLD drivers that don't  let me play some games and those that I can play play very bad because they do not have optimized drivers.
And that is my issue, I do have nvidia's drivers, I do can install and use geforce experience, but the drivers are like SUPER old, and I can not upgrade them to have a little better perfomance on the newest games like fortnite that I plan on playing on this laptop, I don't plan to play Rainbow Six Siege but is is the only game I own that shows the gpu that is being used. And even when the drivers are working, when I mark the option to prefer the nvidia gpu it still uses the integrated graphics... I as far as I know have tried EVERYTHING.
https://linustechtips.com/topic/884940-help-installing-updated-drivers-for-laptop/
But why would I need the intel HD graphics drivers to solve my nvidia drivers issues? My intel drivers are up do date those have no problems, what I need is to be able to update to the most recent nvidia drivers my 960m
Also in a related note, with the old drivers, I can not use the 960m to play games despite chosing it over hd graphics in nvidia control panel, and I read that this happens when a couple of services are stopped, but I don't even have those services listed in my services list. What the heck is going on.
