When i boot the q-code should stay at A0 but after it hits A0 now it goes to 40, everything is running fine im just concerned thats all..
Any help would be fantastic :D
My bois version is: 903
CPU: i7 4770k@4.3Ghz GPU: GTX 780ti Motherboard: ROG maximus vi formula PSU: Evga supernova 1000w Platinum
Case: NZXT Switch 810 Memory: g.skill ripjaws X Cooler: Corsair h100i(getting custom loop when i get money next) Storage: Samsung 840 evo 250gb Keyboard: Corsair K95 Mouse: SteelSeries Rival
https://linustechtips.com/topic/88490-maximus-vi-formula-post-concern/
Hey,
Do you have the manual for the motherboard? there is a Q_Code table with all the specific codes explained.
However I did find the .pdf from their website (link below):
http://dlcdnet.asus.com/pub/ASUS/mb/LGA1150/MAXIMUS-VI-FORMULA/E8336_Maximus_VI_Formula.pdf
The code you're referring to, I can't seem to find, but the closest I can find is 0x40 which means "System is waking up from S4 state".
Not sure if it's any help, but if all works fine. I don't think there is any reason to be worried  :D
Elven
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
Have you tried looking up in the manual what code 40 means? The manual has a table to lookup all the error codes your motherboard will give. Does your computer seem to be running abnormally? If it's running fine, then there shouldn't be much to worry about, but you should look it up in the manual anyways just in case it means a component is starting to go bad.
Ya i have searched it found nothing like @Elven ill try clearing my cmos see what the does for me, all is running well i think... the board is quite new same with all the components.
I don't see error code 40 in your manual, but for my RIVE, code "40" (not "0x40") is:
"System is waking up from the S4 sleep state"
If your system is working fine, I wouldn't worry about it.  If you're still worried, though, just open a ticket to ASUS customer support and I'm sure they'll clear it up.  It sounds like someone might have programmed that bios or transcribed the error code incorrectly so that the error codes don't match.
Isopropyl alcohol is all you need for cleaning CPU's and motherboard components.  No, you don't need [insert cleaning solution here].  -Source: PhD Student, Chemistry
Why overclockers should understand Load-Line Calibration.
ASUS Rampage IV Black Edition || i7 3930k @ 4.5 GHz || 32 GB Corsair Vengeance CL8 || ASUS GTX 780 DCuII || ASUS Xonar Essence STX || XFX PRO 1000W
okay so i just updated through windows update and its back to A0 so windows stop scaring me lol.
Edited by airdeano
Language
