So I am looking to get a new CPU since I feel like its not doing as much as I'd like. It is also old.
My current CPU is the AMD Athlon x4 860k (quadcore, 3700Mhz, 2 cores, 4 logical processors)
I'm looking to get a new cpu that is compatible and far better.
Restrictions of the cpu im looking for;
1. Must be compatible(obviously)
2. Must have a much greater processing power(I don't want to buy something that is only slightly better, it must be worth buying)
3. Limitation of $250 CAD(Most I can budget on a new cpu, so please find something less than that)
My PC is custom built by a friend and I don't really know too much about the parts inside. I'm also new to windows 10 so I don't quite know how to fetch information like what mobo im using
https://linustechtips.com/topic/884511-need-help-finding-a-better-cpu/
You reached the end of this socket already, so either the mobo goes away or you buy a big air cooler and push higher overclocks.
With this amount of money, 2nd gen and 3rd gen i5s or Xeon E3 v2 and v1 should all be within reach, along with motherboards.
Desktop benching:
