So I recently built a new computer (link to build below) and it is great. Except I am running into a problem with the microphone. My computer detects my microphone, but doesn't pick up any sound. I have scoured the internet for answers trying everything. I have tried: 1. Setting microphone as default device 2. Trying both the front microphone and rear microphone port 3. Making sure microphone is enabled 4. Updating the driver 5. Uninstalling the driver and restarting windows 6. Adjusting the settings such as raising the decibel level and other stuff 7. Trying different microphones 8. Trying to use my phone as a microphone (this failed probably due to a failure in set up on my part.) Applications such as discord recognize the microphone, and that it is outputting a constant stream of audio, but no actual sound. I suspect that it has something to do with my motherboard but I'm not quite sure. Any advice is appreciated. Thank you.
-My Build
-I forgot to add my OS is Windows 10
https://linustechtips.com/topic/884365-need-help-with-microphone/
