So currently i'm using 3 corsair Air Series AF120's, I've got one on top for exhaust, another in the back for exhaust and one in the front for intake and am using the NH-L9i from Noctua for CPU duties (40c idle, 60c under load), GPU however get's pretty hot (70+c). The case i'm using is as follows: "Thermaltake Versa H15", i cheated out here in favour of the rest of the components.
I had a i5-7600k which was overclocked, however will be moving to a newer platform (z370) & CPU (i5-8600k) just for the extra horses in CPU heavy workloads, what sort of CPU cooler should i be looking at to tame this beast & is my current config (CPU cooler aside) fine?
https://linustechtips.com/topic/884091-help-with-my-setup/
If you want to over lock the 8600k anywhere near 5ghz you will need a better cooler, I have an 8700k (very similar overclocking) and I am limited to 5ghz on my cryorig h7 due to thermals. I would personally recommend something along the lines of a noctua d15 or a be quiet dark rock pro 3; or a 240/280 aio if you’re into that.
Also move the top fan to the front so you don’t have negative pressure
Edited by Audherbagn
Typo
https://linustechtips.com/topic/884091-help-with-my-setup/#findComment-10920325
That cooler is pretty small and your case is pretty big.  If you want to stay Noctua then go with something like the NH-U14S.  That will take anything the  8600K can dish out.
https://linustechtips.com/topic/884091-help-with-my-setup/#findComment-10920335
Where are you shopping/located? Budget?
What graphics card do you have?
https://linustechtips.com/topic/884091-help-with-my-setup/#findComment-10920655
England, specifically Leeds. As for where i'm shopping: https://m.cclonline.com/ (local retailer, cheaper prices than everywhere else). Budget is around £120, and i have a Palit GTX 1060 Dual 6GB.
Edit: fuck me formatting is cancer on Mobile
https://linustechtips.com/topic/884091-help-with-my-setup/#findComment-10923640
Your graphics card temps are fine.
An H5 Ultimate or NH-D15 would work well.
https://m.cclonline.com/product/225935/CR-H5B/CPU-Coolers/Cryorig-H5-Ultimate-Single-Tower-Heatsink-with-140mm-Fan-Black-Frame/CLR1379/
https://m.cclonline.com/product/159305/NH-D15/CPU-Coolers/Noctua-NH-D15-Dual-Radiator-Quiet-CPU-Cooler-with-two-NH-A15-Fans/CLR0821/
https://linustechtips.com/topic/884091-help-with-my-setup/#findComment-10923702
