Fan Control
Solved by kizoku_95,
YES it will run at its max rpm if the fan speed is set to max in the BIOS!
What fans are you using ?
BANGINGxBT ·
Posted in Console Gaming1 -
Vertinari ·
Posted in Troubleshooting1 -
AngelaHornung ·
2
NeuronButter ·
Posted in Troubleshooting0 -
3
4
Bactraxed ·
Posted in New Builds and Planning1 -
jkb ·
Posted in Troubleshooting2
