Silent Keyboard Help
Solved by bellabichon,
If you have the cash to spare, I would personally get the G810. I've had that keyboard for about 2 years now, and it's never let me down. The keys are crisp enough that you know that you've pushed a key, but the Romer-G switches don't have a loud clicking sound. The one downfall of the keyboard is the software. It doesn't have that many lighting effects built in, but with some tweaking, you can make your own quite easily.
