Specs? Has it worked before? Newly built system?
gimme a sec gotta find my crystal ball and answer those questions
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/883552-won%E2%80%99t-post/#findComment-10914587
Worked before, had it for a few weeks
Core i5 8600k
RX 580 STRIX
z370g mobo
16 gigs of gskill trident ram
h100i v2 cooler
supernova g3 psu
https://linustechtips.com/topic/883552-won%E2%80%99t-post/#findComment-10914680
6 minutes ago, The Lorax said:
Also, when I try to turn it on with the gpu, the vga led turns on
Well, you changed something since it was last working. What was it?
SPECS:
https://linustechtips.com/topic/883552-won%E2%80%99t-post/#findComment-10914904
1 minute ago, The Lorax said:
I tried to install a rgb strip, but once it failed I took it out.
I bet you bumped something, or unplugged something, hell maybe even zapped something, killing it.
SPECS:
https://linustechtips.com/topic/883552-won%E2%80%99t-post/#findComment-10915040
I have searched the mobo for bent or broken capacitors, but found none. I don’t think I could have zapped it because I had the system powered down when I changed everything.
https://linustechtips.com/topic/883552-won%E2%80%99t-post/#findComment-10915063
But were you grounded? And mobo pins aren't the only thing that could have been damaged. Hell, maybe, somehow, you broke the BIOS chip by hitting it or something.
SPECS:
https://linustechtips.com/topic/883552-won%E2%80%99t-post/#findComment-10915072
I was grounded. But I just tested the 2 fan headers on my board and found that they aren’t working either
https://linustechtips.com/topic/883552-won%E2%80%99t-post/#findComment-10915179
Dead motherboard, I bet.
SPECS:
https://linustechtips.com/topic/883552-won%E2%80%99t-post/#findComment-10915184
Just now, The Lorax said:
Really? The cpu fan header works and so do the other connections. No beep codes or anything... I’m trying to be an optimist
Try removing the GPU and RAM, see if it gives you any error codes (other than RAM and GPU missing, obviously).
SPECS:
https://linustechtips.com/topic/883552-won%E2%80%99t-post/#findComment-10915283
