That's quite odd...I would understand if it were malfunctioning on headphones, but speakers? Only recommendation is to just reset your phone to factory settings, then restore. If the problem persists, contact apple--nothing else you can do.
"May your frame rates be high and your temperatures low"
I misread titles/posts way too often--correct me if I don't.
I’ll try apple support later then. I can’t just reset because I have important information on my phone.
Can you not backup to your computer, using iTunes? You can always backup, reset, then restore.
