Hello guys i was wondering if Corsair Hydro Series H115i Extreme Performance Liquid CPU Cooler will fit in my case which is corsair - spec-01 red atx mid tower or not ? And if it’s fit do I need to change my PSU which is Aerocool KCAS 700W ?
Thanks ..
My Rig :
Motherboard:
Asus z170-K
RAM:
16 GB
CPU:
i7-6700
GPU:
Gigabyte Aorus 1080 ti Xtreme Edition
PSU:
Aerocool KCAS 700W
https://linustechtips.com/topic/881246-liquid-cooling/
The 6700 is a locked CPU so it would be pointless and a waste of money to get a cooler like that, all you really need is one of these... https://uk.pcpartpicker.com/product/93Crxr/cryorig-cpu-cooler-h7
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/881246-liquid-cooling/#findComment-10892986
well, you CAN mount 2 140mm fans in the front, but you'd likely have to remove all the drive bays to shove it in there. It does not look like they give you a hell of a lot of room up front.
I'm gonna go with no, unless you rip out the drive bays.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/881246-liquid-cooling/#findComment-10893127
  • 3 weeks later...
